Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 08-17-2012, 10:32 AM   #1
Vinyl window leak
The vinyl window in my dining room appears to have a leak at one of the corners. After a heavy rain I noticed water from one of the corners. After the area dried, I pourd some water onto the windo frame just inside the screen and it bagan leaking again on the inside, looks like at the seam. Not sure if this is structural damage or a drainage issue. If the seam where the side and bottom come together is bad, can this be repaired?
Replacememt window. Aluminum siding. Will work on the photos. Just wondering if the window itself can be reapired if it is leaking at the manufactured seam?
Is there a way to repair a leaking manufactured seam of a vinyl window?
Jim417 is offline   Reply With Quote
Old 08-17-2012, 10:35 AM   #2
Vinyl window leak
Yes, but without a picture and some more info it's anyone guess how to.
Pictures of the inside where the leak shows will do little good, need one of the outside.
New constrution or replacement window?
What type siding do you have?
Jim417 (08-17-2012)
Old 08-17-2012, 10:58 AM   #3
Vinyl window leak
Depends, it a hair line crack or a wide gap?
How old are the windows? Most companys would warrenty it.
Old 08-18-2012, 10:46 AM   #4
Moderator
kwikfishron's Avatar
Vinyl window leak
I've successfully made that type of repair before with epoxy but i'ts kind of a case by case thing. Can't say with yours.
Have you checked to see if the weep holes are plugged up?
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 08-18-2012, 12:58 PM   #5
Exterior Construction
Windows on Wash's Avatar
Vinyl window leak
+1
Totally case by case.
Most attempts at repairs fail that I have seen.
Old 08-18-2012, 01:16 PM   #6
Moderator
Vinyl window leak
Knowing the materials your working with and proper prep are key.
If you're not dialed in with both then failure is a given.
-NEW MEMBERS-
Old 08-18-2012, 01:30 PM   #7
Vinyl window leak
Yes. Most I have seen are homeowner or poor contractor work. Adding a bunch of caulking is not going to get it done.
I would also add that most windows that are suffering from this defect are likely not worth replacing.
Plastic welding is the best option but it requires a bit more working area than does laying down some sealant.
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 03:05 PM
Vinyl Replacement Window Questions Marty1Mc Windows and Doors 6 05-22-2011 11:36 PM
Vinyl window installation questions Hexar Remodeling 9 01-06-2011 08:54 PM
Vinyl Window rmass28 Building & Construction 4 01-27-2008 06:58 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
