Vinyl Window Installation - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-25-2013, 11:00 AM   #1
vinyl window installation
This general contractor used block frame windows without nailing fins in our stick frame house and the windows are sliders. We were going to insulate around the inside of the trim and saw the jamb screws holding the window are screwed into the sheathing and not into the jamb or r/o. The contractor stated we don't have to cut any inside trim or exterior cedar sliding to the house using block frame windows without nailing fins. Is this install to code? Also, is this the appropriate windows that were installed in our home?
Should the flexible straight flash be underneath the siding, instead of being on top of the siding when he put the 1X4 trim on and caulked around the 1x4 trim.
station1111 is offline   Reply With Quote
Vinyl corner guard for bathroom window? CubsWin Windows and Doors 9 05-22-2012 07:40 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
