Vinyl Window Install - Windows and Doors - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-29-2013, 02:32 PM   #31
Rewards Points: 85
OP,
Just as an FYI, Angie's List does have a complaint resolution process as well.
http://www.angieslist.com/complaint-resolution-faq.htm
You do have the option of engaging it as well. However, IMO I would not rely on it as a sole means of resolution.
steelgoddess is offline   Reply With Quote
The Following User Says Thank You to steelgoddess For This Useful Post:
station1111 (12-29-2013)
Old 12-29-2013, 04:26 PM   #32
Thanks for that tip. We will check it out.
station1111 is offline   Reply With Quote
Old 07-07-2014, 04:12 PM   #33
Rewards Points: 152
Have you called the state agency that issued the license for this contractor? They may have suggestions on how to resolve this issue (quite a bit of time has passed - but I'd call anyhow, especially if you notified the contractor in writing of your concerns).
Was this a contractor recommended by Milgard? If yes, I'd also contact Milgard. If you still need a contractor to fix the problems, I'd go with one recommended by Milgard - you can find this information on their website.
This will only get resolved if you are proactive in resolving it. What have you done so far? From your May response, I'm wondering if you have done anything other than talk to the contractor?
The state licensing agency likely records complaints against contractors.
lazzlazz is offline   Reply With Quote
Vinyl window installation questions Hexar Remodeling 9 01-06-2011 07:54 PM
Should we really install bow window this way? JBrowning Building & Construction 6 09-16-2010 09:40 PM
Window Install? sod Building & Construction 3 10-26-2008 07:02 AM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 10:51 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
