Vinyl Window Frame Seal? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-24-2013, 09:01 PM   #1
Rewards Points: 87
Vinyl window frames supposed to be airtight in order to provide the best energy barrier, right?
If a person needed to bring a coax cable from outside to inside, would it be OK to drill a hole through the window frame, pull the cable through, then seal the frame around the cable (both inside and outside) with silicone caulk?
TIA.
huesmann is offline   Reply With Quote
Old 10-25-2013, 06:15 AM   #2
Rewards Points: 14,300
Never!!!!!
Run it through the wall, under the floor, through the attic, anyplace but through a window frame.
HomeSealed (10-26-2013)
Old 10-25-2013, 06:19 AM   #3
Rewards Points: 87
Why is that?
Old 10-25-2013, 08:45 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Compromise structural integrity and seal, void warranty, look terrible, throw up red flags to future potential buyers and/or inspectors...
You should be able to find a more sensible place to do this.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
joecaption (10-25-2013)
Old 10-26-2013, 05:37 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Originally Posted by huesmann View Post
Why is that?
Joe,
Feel free to give me a ring and I can stop by and tell you were to run it.
Old 10-29-2013, 02:18 PM   #6
Rewards Points: 87
Thanks for the offer. I guess I'll just drill a hole through the CMU and brick facing, then. I'm replacing an aluminum-framed window with vinyl; one of the POs drilled a hole through the aluminum frame for the coax cable entry point.
New window in old frame KurtP Building & Construction 0 09-12-2010 10:10 AM
Window frame not flush with finished wall Stubbie Carpentry 9 06-24-2008 02:38 PM
Rear Window Seal Crista Automotive Repairs 2 11-18-2007 10:16 AM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 11:13 AM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
