Vinyl Thermal Properties - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-16-2013, 06:46 PM   #1
Vinyl thermal properties
I'm trying to retrofit a sliding door with a better weather sealing system. I'm essentially adding a vinyl flap to certain parts of the door and I'm attempting to use the flexible vinyl seal from a garage door stop molding. I've got two different make/model vinyl flaps and am trying to figure out which to use because they look identical, but apparently aren't! One of the flaps actually permits some light to pass through it, while the other piece of vinyl permits zero light to shine through. Does this shining light through the material possibly relate to the thermal properties of the seal? And by the way, both vinyl flaps have the exact same thickness; they look identical.
-Segal
segal is offline   Reply With Quote
Old 05-27-2013, 08:19 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,002
Don't think it would have much, if anything, to do with the thermal properties and especially in such a small cross sectional area.
The flap that does not allow light to penetrate probably has more material to it and therefore should hold up better over time.
The Following User Says Thank You to Windows on Wash For This Useful Post:
segal (05-27-2013)
framing for vinyl wind barrier (See photos) Carolyn252 Building & Construction 2 09-02-2011 04:50 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 05:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
