Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 11-13-2012, 11:21 AM   #1
Vinyl Interior Trim Installation
I removed the trim to do some work on the drywall around the window. The trim was held in place with an adhesive strip and caulking. There is a 1/4" gap around the window 2" deep.
Should I put some type of insulation in there and find some new adhesive tape?
RalphPeters is offline   Reply With Quote
Old 11-13-2012, 11:29 AM   #2
From that picture I'm not seeing a wide enough gap to get an expanding foam tube in the gap. It should have been done before the tile went up.
A 4-1/2" angle grinder with a diamond blade could be used to open up the gap in a few places so it will slip in.
RalphPeters (11-13-2012)
Old 11-13-2012, 11:51 AM   #3
Im not sure if we are talking about the same gap. It's the one between the window glass and the drywall. The trim will cover it.
Trafficmaster Allure - Underlayment? HuskySkull Flooring 41 09-23-2012 03:28 PM
Luxury Vinyl Flooring installation kleinline44 Flooring 1 03-06-2011 10:23 PM
Installation Tips on Vinyl Shutters over James Hardie Siding elroyyboy Remodeling 1 05-03-2010 10:37 AM
vinyl fence installation dedsr Landscaping & Lawn Care 3 12-10-2004 10:59 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
