Velux Skylight - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 02:36 PM   #1
velux skylight
i cannot figure out how to install the rain sensor. the curb is 3.5". there is a cord that i am to connect to an inside connection. how do i get it through. am i supposed to drill a hole in the curb and flashing. im on the roof now and cant see any way to do it without drilling a hole.
ferguselora is offline   Reply With Quote
Old 10-23-2011, 02:59 PM   #2
DIY staff
Rewards Points: 7,174
Here is a PDF with instructions--450432-1000WLA510.pdf (application/pdf Object)
Looks like there are no holes of drilling needed.
The metal shroud covering the window is loosened --sensor stuck into the top cover--then the wire tucked under the tin shroud--and back into the house.
I've installed a few Velux but never the rain sensor---Did you loose the instructions?
Framing in Velux Skylight Scott531 Building & Construction 4 08-19-2011 04:32 PM
skylight self stick flashing advice Earl0101 Roofing/Siding 2 04-30-2011 09:55 AM
Dome skylight leaking AAK Roofing/Siding 1 10-08-2010 05:47 PM
Need Hex Bolt for Older Velux Skylight xquercus Roofing/Siding 0 05-26-2010 01:19 PM
Velux skylight install with 10 degree slope and corrugated tin roofing oliverbutthead Roofing/Siding 8 07-06-2008 09:23 PM
