Using Acrylic Plexiglass To Make An Old Window "double Pane" - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-13-2014, 07:18 PM   #1
Rewards Points: 156
using acrylic plexiglass to make an old window "double pane"
I have a nice bow window on the front of my home, but the problem is that it is single pane glass, and it's like having a huge hole in the front of the house. I am thinking of a good idea of taking some acrylic plexiglas, and cutting it to fit over the mullions, then fastening it down with small screws to make like a double pane, with an air gap of about 1 inch between the original glass, and the acrylic. I can do this with about $250 worth of acrylic.
Does this sound like it will work good? Am I wasting my money with minimal results or is this a great, inexpensive way around buying a new bow windows for $10,000 or so. I know it's not going to be as tight as a new window, but I am hoping it will make the living room at least a little less drafty. I am thinking that moisture settling in between the layers may be a problem, and for that reason I don't want to seal the layers together, but be able to remove the screws, take the acrylic panes off, and clean any condensation off. Also, the screws would insure there would not be a "perfect" airtight seal and the layers could breathe a slight bit and avoid the moisture problem altogether.
What are you thoughts on this? Crazy or kinda smart?
Here's a picture of the window I cropped from a Christmas photo. The mullions are about 3/4 inch wide. I also plan to cut acrylic for the openable portions the same size as the screens.
av-geek is offline   Reply With Quote
Old 02-13-2014, 08:01 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Same concept as an interior storm. In fact, you may want to explore that option for a superior fit and finish. Regarding the seal, it is precisely that which will keep moisture from building up between. No seal will result in more condensation on the outer unit, similar to what you see on most storm windows.
Another thing to keep in mind is that the seat and head of that unit may not be well insulated either. Adding 2" of XPS foam board to the exterior of that seat board would help.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
oberon (02-14-2014)
Old 02-13-2014, 09:10 PM   #3
Rewards Points: 240
exactly. seal them up. i have 2 old wood windows, right next to each other.
they are going to be replaced. but to make them better, to get through this winter. i took the sashes from same size windows that i did replace. put some caulk on them and screwed them on = 2 pane window. i works great. the other has a little gap (that i didn't catch until it got too cold to fix). and it fogs sometimes.
Fix'n it is offline   Reply With Quote
Old 02-13-2014, 09:51 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 768
Plexi-glass will yellow and become cloudy in no time and will scratch easily, it would be a waste of good money to use that. I will leave the advice up to the window experts here about the windows, just wanted you to know about the plexi-glass.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
joecaption (02-13-2014)
Old 02-13-2014, 09:56 PM   #5
Rewards Points: 14,290
Add it crazes to the list.
Something's really wrong with that price for a new window.
Get some more prices.
Stay out of the box stores!
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Wasp nest above window (pic), how to make sure they're gone? 52Caddy Pest Control 2 03-16-2010 08:54 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
