Use Of Spring Hinges - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 09:30 AM   #1
Use of Spring Hinges
When using spring hinges on a standard 3' x 7' door, how many should I use? Are they load bearing like a standard hinge?
sjm007 is offline   Reply With Quote
Old 01-11-2012, 09:36 AM   #2
Rewards Points: 12,882
It's best to use three hindges on any door. It speads out the load on the hindges.
Why are you going with spring hindges?
7' would not be a standard door 6'8" would be standard.
Old 01-11-2012, 09:46 PM   #3
Missouri Bound's Avatar
Some are not load bearing. The suggested door weight is on the packaging in most cases. Do you just want the door to close or slam? Perhaps a closer of sorts would be a better choice.
Old 01-12-2012, 12:59 AM   #4
Rewards Points: 2,202
When using 3 make sure you wind them all the same
mae-ling is offline   Reply With Quote
Old 01-16-2012, 07:03 PM   #5
43 years in construction
Arkitexas's Avatar
Mortised spring butt hinges can carry nearly the same weight as a standard 5 knuckle hinge. The number of spring hinges needed is based on the weight of the door to be closed. Spring hinges are not recommended for exterior door applications. Spring torsion is adjustable and is usually set just high enough to close the door (slowly). Stanley Hinge Company recommends the following:
Assuming 3.5"x3.5" full mortised butt hinges in a residential application,
Doors 50 lbs. or less: One 2060-R spring hinge plus two standard 5 knuckle hinges such as the FBB-179
Doors 85 lbs. or less: Two 2060-R spring hinges plus one standard 5 knuckle hinges such as the FBB-179
Doors 110 lbs. or less: Three 2060-R spring hinges
When mixing spring and non-spring hinges, the centerline location of the barrel must match exactly or the door will bind. Always use the same brand when mixing hinge types.
Rick
Arkitexas is offline   Reply With Quote
Ever install a door spring on a 2 door? noquacks Automotive Repairs 19 09-17-2011 07:29 AM
Space for hinges on custom closet doors nrk411 Carpentry 3 07-11-2010 08:34 PM
Blum hinges from 15 years ago?? MI-Roger Carpentry 14 02-23-2010 01:44 PM
Cabinet hinges don't fit... arghhhh!!! pisces7378 General DIY Discussions 7 12-25-2009 08:47 PM
Spring Hinges jb198606 General DIY Discussions 3 02-06-2006 09:40 PM
