Upstairs Window Heights? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-18-2014, 09:24 PM   #1
Rewards Points: 213
Upstairs window heights?
Does anyone know the minimum window height for window opening for the second floor of a house.
We were going to replace the old wood ones with vinyl. Right now they start 24" off the floor.
This is in Los Angeles
crayola110 is offline   Reply With Quote
Old 12-18-2014, 09:47 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,244
Do you mean minimum total height or height from the floor?
The Following User Says Thank You to Windows on Wash For This Useful Post:
crayola110 (12-19-2014)
Old 12-18-2014, 11:20 PM   #3
Rewards Points: 213
Height from floor. The window opening starts 24" from the floor.
thanks
Old 12-18-2014, 11:51 PM   #4
Rewards Points: 6,652
thanks
Yours will have to be Tempered glass at that height from the floor. Your local building code office in LA will have the information, which is available online at their website.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 12-19-2014, 12:11 AM   #5
Rewards Points: 213
I've been searching online for this info for hours but could not find it
http://dpw.lacounty.gov/BSD/lib/fp/B...iew%20List.pdf
from what I read it looks like the window sill just has to be 24 in from floor? but I don't see where it has to be tempered or anything about second story floors?
Old 12-19-2014, 12:58 AM   #6
All of my windows sit around 24" from the floor and are all Tempered Double pane windows. My storms out are not, because they are about 5' to 5-1/2' off of the ground for the windows. They are just standard Single pane glass for the storm's.
With you being in Earthquake country, most likely it would be wise to get Tempered/safety glass type windows, regardless of the height from the floor.
Old 12-19-2014, 06:41 AM   #7
kwikfishron's Avatar
Rewards Points: 774
18" or below off the floor for tempered.
https://mybuildingpermit.com/Constuc...et%2019_09.pdf
Of coarse you should always check locally to be sure.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Windows on Wash (12-19-2014)
Old 12-19-2014, 01:17 PM   #8
Rewards Points: 124
It will depend on what local building code office has set it at. You might have to call someone there to get your answer.
ACWindows is offline   Reply With Quote
Old 12-19-2014, 08:04 PM   #9
Rewards Points: 213
So based on that I would not have to temper it? I just need regular windows right?
It's second story 24 in off the floor.
Old 12-19-2014, 08:58 PM   #10
Again it is going to be up to the Building Codes office to tell you if you need tempered or not, since you are in Earthquake country.
Pass Through Counter Top & Window Setup Questions miamicuse Building & Construction 6 05-25-2013 08:13 PM
General window install questions miamicuse Windows and Doors 9 04-23-2013 08:05 PM
Slanted window - should I correct? miamicuse Windows and Doors 11 04-16-2013 06:59 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
