Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-18-2012, 12:38 AM   #1
uneven gap at bottom of door
I live in what my neighbors call a "hurricane house." Every repair done after Katrina is like the project of a 4 year old. We moved in 3 months ago and the palmetto bugs and other assorted cockroaches were ridiculous. One of the entry points is a door in the kitchen that I tried to put a door sweep on, but still has an enormous gap on the right side. The threshold is totally uneven concrete and the door itself is a very odd shape, not a rectangle to be sure. I have no idea how to close this gap. I've been shoving plastic bags under the door to try to keep the bugs out, but I'm sure there is a better way?!!!
nolahand is offline   Reply With Quote
Old 09-18-2012, 12:40 AM   #2
please post some pic's
epson is offline   Reply With Quote
Old 09-18-2012, 12:08 PM   #3
Need to figure out if it's the floor that sunk, or the framing and jambs of the door are off.
Just check it with a level.
With a picture and more info on how out of level and plumb the door is we can figure it out.
Old 09-18-2012, 12:14 PM   #4
Originally Posted by nolahand View Post
but still has an enormous gap on the right side...
which side is the right side? If you are on the outside of the door the right side is different than if you were on the inside of the door.
Hinge side of door or lock side of door would be a better description.
hammerlane is offline   Reply With Quote
Old 09-18-2012, 01:31 PM   #5
Here are some photos...
uneven gap at bottom of door-photo-2012-09-18-12.16.jpg   uneven gap at bottom of door-photo-2012-09-18-12.18.jpg   uneven gap at bottom of door-photo-2012-09-18-12.19-2.jpg
Old 09-18-2012, 02:07 PM   #6
There's several differant ways to fix it.
The simplest way but not the best way would be to cut a tapered shim, that's been primed and painted on all sides and attach it to the bottom of the door.
The best way would be to install an adjustabe threshold and add a seal to the bottom of the door.
A lot more work and you would have to have an ossilating saw to be able to get the sides to fit properly. But it can be done.
You also would have to cut the door shorter inorder to fit the new threshold.
http://www.doorthresholds.us/36-in-o...ll-finish.html
Front Door inswing will hit bottom step JStephens11 Building & Construction 12 08-28-2012 11:54 PM
Sealing bottom of exterior door GLS0628 Windows and Doors 2 08-26-2012 06:18 PM
Patio door bottom sill over brick/concrete block cjf1980 Building & Construction 18 04-12-2012 10:56 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 12:23 PM
