Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-09-2011, 09:59 PM   #1
Undersized Doors
Does anyone know where to get undersized doors? I need a 78" tall door for an exterior opening. I would actually like french doors. The opening is a little narrower than average as well.
krombie19 is offline   Reply With Quote
Old 09-09-2011, 10:14 PM   #2
Undersized Doors
You can purchase a standard size door and cut it down.
epson is offline   Reply With Quote
Old 09-09-2011, 10:23 PM   #3
Undersized Doors
This is for an exterior door so I would prefer not to use a wooden door.
Old 09-09-2011, 10:29 PM   #4
Undersized Doors
try this site: http://search.mobilehomepartsstore.c...-78%2522--list
Old 09-10-2011, 12:08 AM   #5
A door a day is all I ask
TheDoorGuy's Avatar
Undersized Doors
Hi there,
You didn't say what your width is but these doors come in 6'6 callout height.
http://thermatru.com/products/entry/...te-s118/go:dl/
They will actually net out 1" under that because of the way they talk about height of fiberglass and steel doors.
You can probably take up that extra space with a higher threshold and a different door shoe.
The widths they offer range from 2'0 to 3'0....
Fiberglass is the way to go for exterior doors...20 year warranties are typical.
Best of luck with the project!
RC/DG
Richard The Door Guy
TheDoorGuy is offline   Reply With Quote
Old 09-10-2011, 03:38 PM   #6
Windows & Remodeling
HomeSealed's Avatar
Undersized Doors
Krombie, most door manufacturers will cut a door down to whatever exact height that you need. We order ours through a distributor, but I believe that Lowes sells Thermatru. I'm sure that they have access to all of the same options/features. Just let them know the exact size that you need, and they should be able to get it. It will probably cost an extra $100 or so for the cut-down.
HomeSealed is offline   Reply With Quote
Old 09-10-2011, 03:53 PM   #7
Moderator
kwikfishron's Avatar
Undersized Doors
Box Stores have quite the up charge for anything custom ordered on a door. This is a case where ordering through a Lumber Yard would be less expensive.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 09-10-2011, 06:37 PM   #8
HomeSealed's Avatar
Undersized Doors
I don't know if that would be true here Ron... The end price would probably be pretty close I'm guessing. The difference is that the stuff box stores keep in stock is just sold way cheaper because they buy in bulk. For instance, a stocking primed 6 panel fiberglass door may cost $250 at Lowes and $350 through a distributor, but a special order one is probably the same price through either, or at least much closer.... I don't know, I could be wrong, I never buy from box stores. That is just how I always understood it to be.
Old 09-10-2011, 07:01 PM   #9
Moderator
Undersized Doors
I could be wrong since I’m speaking without personal knowledge on this one. A few times on this site posters looking for odd sized door options have mentioned that their $250 box store door became $600-$700 when they wanted some unconventional size. Maybe OP will price it both ways and let us know.
-NEW MEMBERS-
Old 09-11-2011, 10:27 PM   #10
HomeSealed's Avatar
Undersized Doors
Fair enough, hopefully we'll find out one way or the other..
The Following User Says Thank You to HomeSealed For This Useful Post:
kwikfishron (09-11-2011)
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 08:00 AM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 11:51 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
