Triple Pane Windows - Worth It? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 01:26 AM   #1
Triple Pane Windows - Worth it?
Some manufacturers are making triple pane windows now. They even offer an option of in-window blinds that sit in the third pane. Are these windows worth the extra $$$ or can a double pane window perform better?
JackOfAllTrades is offline   Reply With Quote
Old 01-04-2012, 07:12 AM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Whether or not they are worth it depends on a lot of factors, including the location of your home, goals for the project, cost to upgrade, etc.... The performance is indicated by the u-value. Generally triple pane will be better in this regard, but there are some very high quality windows out there that have better ratings with double pane than others with triple.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-04-2012, 07:57 AM   #3
Yep, lot of variables. The most important he mentioned is the actual U factor. But in general, triple pane is only economically better in the far north cold climates.
Old 01-04-2012, 08:50 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 832
+1 to both of this window jokers.
Is it worth it, can be. If opting for triple pane windows cut into the construction budget that made you then choose a 2x4 wall and R-13 vs. a 2x6 and R-19, then no.
If it cuts into the budge where you only blow R-30 in the attic vs R-50, then no.
Triple pane is a great option if you can swing it and given the impact of the thermal weak spot in the wall assembly with a double pane, it can have a greater than perceived impact.
caulking old wood windows andyman Windows and Doors 10 12-31-2011 04:39 PM
double pane windows trw43 Windows and Doors 2 12-30-2011 08:15 AM
Refilling Argon thermal pane windows Chiurato Windows and Doors 5 03-31-2011 08:25 AM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
