#1 |
Triple brick
Replacing front door in triple brick farmhouse. Can I remove all old wood framing?
#2 |
Triple brick
Why would you?
Just remove the door and jambs. |
#3 |
Exterior Construction
Triple brick
Pictures are worth a thousand words here.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
AHH, SPANS!!!
Triple brick
are you just replacing the slab or is it an entire door unit to fit back in the old door hole?
| Display Modes | |
| Brick veneer is 4 rows below grade- redo or leave? | cbrc5eric | Building & Construction | 11 | 12-27-2011 09:09 PM |
| Started Exposed Brick Wall, Studs within brick, should I stop? | perry167 | Building & Construction | 4 | 01-05-2011 10:41 AM |
| Question Re. Parging Over Brick | Captain.Sassy | Building & Construction | 19 | 06-22-2010 09:50 AM |
| new door through triple brick wall | Mike.F | Building & Construction | 2 | 08-02-2009 05:04 PM |
| Sealing historic brick | tenzo | General Discussion | 2 | 11-22-2008 04:04 PM |
