Trim Around Window That Has Tile Installed Halfway Up Recess? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 12:35 PM   #1
Trim around window that has tile installed halfway up recess?
Hi everyone,
I'm new here and am looking for some advice on what to do with the window in my bathroom.
Right now, the entire bathroom is tiled about halfway up, and when it gets to window, the tile continues into the window recess. I removed the previous owner's valance and would like to add an inner roman shade instead, however, the window looks very unfinished so I was thinking about adding some trim around it.
Is this common practice to do or will it look weird since the trim will stop where the tile starts?It's not in my budget right now to remove/replace tile, so I'm trying to work with it as much as possible.
Any advice would be much appreciated!
Thanks!
Dylan
dleopold623 is offline   Reply With Quote
Old 03-26-2013, 04:47 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
Post up a picture...you will get more feedback.
Old 03-27-2013, 07:58 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
I assume the tile has a bullnose along the top that finishes the tile section, so a piece of window trim cut to fit atop of the bull nose that goes around the window would not look to bad. or some type of rosette/plinth block placed on top of the tile to separate the trim from the tile could work. what type of border goes around the window where it is not tiled now? is it a drywall cased window? thanks
hand drive is offline   Reply With Quote
Do I change the sills when adding window trim? jojomac Carpentry 11 10-22-2012 10:21 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
