Trim 1/16" Off Edge Of Glass? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 12:16 AM   #1
Rewards Points: 682
Trim 1/16" off edge of glass?
I have a piece of glass, 5" wide. I need to trim just 1/16" off the end.
I've heard you can use a sharpening stone, or emery cloth, but it takes a long time. Have you guys done this?
darsunt is offline   Reply With Quote
Old 05-11-2012, 06:43 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,164
You could file it down but be darn careful and make sure you have the proper PPE (forearms, gloves, etc) gear on.
Wet the area as well to keep any dust down.
It will take a little while too.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oberon (05-11-2012)
Old 05-11-2012, 08:46 AM   #3
Rewards Points: 109
How large and thick is this piece of glass?
It's doable, but removing 1/16" by hand you could potentially be looking at a couple of hours or more for even a relatively short edge on a thinner lite. If it's a longer edge and/or thicker lite then the time involved to remove the excess material may be way beyond the value of the glass.
And as WoW pointed out, you absoluely want to make sure that you are wearing the right personal protection...
oberon is offline   Reply With Quote
Old 05-11-2012, 09:05 AM   #4
Rewards Points: 13,458
For that small a piece of glass I'd just go get another piece.
If you took it to a glass shop they could sand it down pretty fast on there wet sander but it would cost more then a new piece of glass most likyl.
Old 05-11-2012, 10:55 AM   #5
Rewards Points: 682
The glass is 1/8" thick.
Sounds difficult. Will have to think about this one.
Old 05-11-2012, 11:00 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
I would gently clamp the glass between two straight pieces of wood just so the 1/16" sticks out, take a diamond tile cuter on a side grinder and grind it off gently, don't try to grind too much at a time, it will over heat the glass and crack it, just grind a little and let it cool then do it again.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 05-11-2012, 12:10 PM   #7
kwikfishron's Avatar
Rewards Points: 412
Hope it' not tempered glass.
kwikfishron is online now   Reply With Quote
Old 05-11-2012, 01:06 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Hmmm, I forgot about that, tempered glass can be be ground off but no more than an 1/8" then you will be taking one heck of a chance it will shatter.
Jim
Old 05-11-2012, 10:27 PM   #9
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Many moons ago I worked for my in-laws in their auto and commercial glazing business. Custom cut glass on site is an everyday occurrence: I used Milwaukee grinder with sanding discs that would remove that amount of material in 5 secs on the jobsite, otherwise if there was time to bring it back to the shop we had a nice wet-grinder that would deliver a nice polished edge.
I would NOT attempt to cut that amount of glass off whether with a glass cutter or diamond blade.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 05-13-2012, 10:59 PM   #10
Sand it off with a belt sander
UFoPilot is offline   Reply With Quote
Old 05-14-2012, 07:41 AM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
I wouldn't try to cut that little amount off either but it can be ground off with a diamond cutter instead of cut off.
Jim
Getting impact windows ! Have two to choose from, which is best ? filo74 General DIY Discussions 13 09-01-2015 02:44 PM
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 10:29 PM
Double-hung window sash glass replacement teetee1 Windows and Doors 1 03-10-2012 11:21 AM
Easiest way to paint/finish baseboard/window/door trim in entire house? Michael-stl Painting 6 02-25-2012 09:30 PM
