Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-11-2012, 03:58 PM   #1
Question
Trick to stop water damage on bottom of outside door frame
Hello,
I installed a new door frame for my client last year. They called me back this summer to find water damage on the bottom right of the frame. I suspect that it is from snow accumulation over the winter.
Does anyone have any tricks to deter this from happening in the future?
Thank You,
Eric N.
http://www.doylestowncontractor.com
ericknotwick is offline   Reply With Quote
Old 09-11-2012, 04:12 PM   #2
Posting a picture would help to figure it out.
Just a few guesses, the door is set closer then 4" of any stoop, deck, any solid surface.
Doors come primed not painted, did anyone paint it two coats of ext. paint?
What's under the threshold on the outside to support it and keep it from twisting?
Old 09-11-2012, 04:30 PM   #3
Exterior Construction
Windows on Wash's Avatar
+1
Edge prime and seal prior to installation.
Old 09-13-2012, 05:18 PM   #4
Bombastic Idiot
notmrjohn's Avatar
Damage is to door frame? Prime, paint/seal all frame sides and ends visible and hidden B4 install. Frame sits on threshold. Trim does not contact deck.
Awning, roof, walls to keep snow and rain away from door, but nothing to trap snow or rain or prevent snow from blowing away.
Tricks? Wand to make snow disappear.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Tags
doylestown contractor, general contractor
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Need help figuring out walk-out basement water intrusion issue toomanypets General Discussion 18 08-29-2011 09:34 PM
Apartment water leak - questions haris General Discussion 2 03-23-2011 08:26 PM
Water damage. How bad can it be? alexin General Discussion 3 08-23-2010 02:53 PM
