Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-07-2012, 08:41 PM   #1
lvc
Top window sash dropping
Hi,
I am new to this board so not sure how to navigate around. Anyway, I have a 100 year old double hung window that is not in good shape. The top window drops down about 6". I need to get this secured before winter--it's getting cold. The lock is broken so it doesn't keep the window closed. I have tried shims and it still drops.
Any suggestions?
The only thing I can think of for a temporary fix would be to lift the window up, drill in screws onto the sides into the frame leaving out a bit of the screw to hold it up. Would that work or will I just ruin the frame of the window. The total wooden window is probably 30" wide by 72" long and it quite heavy.
Please help. Thanks.
lvc is offline   Reply With Quote
Old 10-07-2012, 08:46 PM   #2
Are you looking for something permanent or temp?
A stick (say 1x2 or whatever) cut to length to hold it up works, also prevents break ins - unless they break the glass.
mae-ling is offline   Reply With Quote
Old 10-07-2012, 08:48 PM   #3
Or just install a new replacement window.
No more air leaks, priming, painting, glazing.
Old 10-07-2012, 10:22 PM   #4
lvc
Do you mean two sticks on either side on top of the bottom sash to wedge to the top edge of the window? If so, I tried that before and they buckle from the weight and fall off.
I need something for about 6 months till I can get it professionally replaced or fixed. It's a large stairway window, so I am not concerned about breakin--it's far off the ground.
Old 10-07-2012, 11:09 PM   #5
The top 1/2 of the wdw slides down?
Cut a 2x2 or even a 2x4 that fits under it and sits on the sill.
Or if it only 6 months and no plans to open screw it shut.
Old 10-08-2012, 01:22 PM   #6
lvc
Yes, I was debating the same thing...maybe I should just screw the thing shut. Or, I could try propping the pieces of wood on this sill. Thanks for your input!
Old 10-08-2012, 04:52 PM   #7
Windows & Remodeling
HomeSealed's Avatar
If it is 100yrs old, I'm sure that you have the old rope and pulley balance system. It could be fixed/replaced, but probably not worth the effort. The easiest fix would be to just go to Home Depot and buy a new sash lock for a few bucks. The push it up and lock it shut. It will look a lot better than wood blocks, etc.
HomeSealed is offline   Reply With Quote
Old 10-08-2012, 05:06 PM   #8
lvc
Such a simple fix...I feel so foolish that I never thought of that! And, yes, they are ropes and pullies. Thanks!
The Following User Says Thank You to lvc For This Useful Post:
HomeSealed (10-08-2012)
Tags
window repair, window sash
moving window sash bftjr1944 Carpentry 1 10-26-2010 11:13 PM
Defog window recap greenmax General Discussion 4 05-07-2010 06:00 PM
Replacing window sash with rotten bottom jandrew Carpentry 3 08-31-2008 05:02 PM
Sash Window renovation DED Carpentry 1 05-25-2005 02:32 PM
