Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 07-02-2011, 04:07 PM   #1
tips for working with self leveling compound and recommended tools for the job
Considering applying self leveling compound on a rough basement floor in our rental property (built 1920). Our thought was to apply a garage epoxy paint on top of the self leveled floor. Two questions 1) anybody think it'll work? 2) will the self leveling compond adhere to a floor that has some reminants of a "tar like adhesive" remaining from the old removed tiles. This room essentially serves a a hangout for adolescent boys. Any insight would be welcome. I'm a newbie in posting.
wee1945 is offline   Reply With Quote
Old 07-02-2011, 05:08 PM   #2
Super Moderator
The self leveling compounds are to soft for use as a finished floor---painted or not---Consider a ceramic tile floor on top---there are some nice and cheap tiles available.
Jiff Set mixed with Linewebers liquid latex will bond to old 'cut back' adhesive.
I am sure that there are other brands that are approved for that application.
some require priming before application to ensure a good bond,
Tools? A bucket---- a drill---a mixing wand---a trowel and maybe a iron garden rake.
Mix it to the instructions--if right it will be very thin and runny---pour it on the floor where you want it--very quickly smooth it out with the trowel or a screed board and then let it float itself flat.
work fast---after 2 or 3 minutes you better be done or you will have a mess. Fast that's the key.
Old 07-03-2011, 07:44 AM   #3
also.........make sure all holes, crevices, etc., are plugged, because it will find them and run out.
Old 07-03-2011, 07:54 AM   #4
Super Moderator
I worked at a tile shop many years ago------A setter came in to pick up 6 more bags of mix to finish up a job---He was scratching his head--said he was usually pretty good at estimating how much was needed for a job.
I saw him a few days later and he had a funny story--it seems there was a hole he hadn't noticed---right above an open washing machine!!!!
Customer got a new machine---setter got a hernia (and a very funny story)
Tags
flooring advice, general discussion, tools
Self leveling compound bcarwell Flooring 4 09-07-2012 01:27 PM
self leveling compound help/advice needed clubjuggler Tiling, ceramics, marble 3 01-27-2010 09:31 PM
Self Leveling compound on hard wood floors?? Tbizzy2 General Discussion 3 05-22-2008 12:11 PM
