#1 |
Timed opening of window curtains?
Hi all,
I'm wondering what it would take to set up a "sunlight wake-up alarm", but instead of having it be a 100$ lamp from Amazon (or wherever), use the actual sun. I have blackout curtains, so my idea is this: - Outlet timer (you know the kind people use when they go on vacation) - Small motor When the timer reaches the specified time, it activates, allowing power to flow to the motor. The motor pulls a cord which is attached to the curtains (think theatre style) The only problem is getting the motor to turn off once the curtains are pulled back, and beyond that I'm not really sure where to start since I've not done something like this before. Thanks ahead of time for any feedback. |
#2 |
probably doable, but the position of the sun changes during the year and there will be days of no sun.
what is your location? |
#3 |
Windows & Remodeling
Have you searched the web on this? I have to think that there is probably a product already in existence... If not, you had better remove this post and take your idea to Shark Tank!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 | |
sparky
Timed opening of window curtains?Quote:
(switched for the party weekend )
#5 | |
#6 |
in true diy spirit, here is a link to making your own
http://www.instructables.com/id/Buil...oller-For-Les/ |
| Display Modes | |
| Replacing exterior door with window plus wall in brick opening | mje113 | Remodeling | 2 | 11-07-2012 03:16 PM |
| Help with my Egress Question | brockmiera | Building & Construction | 19 | 10-30-2012 04:20 PM |
| window vs. brick arched opening vs. aluminum flashing | amakarevic | Windows and Doors | 10 | 02-04-2012 03:33 PM |
| Condensation on fiberglass window frame | creamaster | General Discussion | 11 | 01-05-2012 08:42 PM |
| Defog window recap | greenmax | General Discussion | 4 | 05-07-2010 06:00 PM |
