Tilt In To Clean - Not For Top Pane! - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 04:08 PM   #1
Rewards Points: 348
Tilt in to Clean - Not for Top Pane!
Trying to clean my windows, scrape some of the paint of them too. In some parts of the house, the windows are pretty high, so getting at them with a ladder is not very comfortable....
I can get the bottom pane to tilt in no problem. Just push in on the "tracks" while pulling the window toward me, and it pops right out. But how do I do the top one? If I try to tilt in, I need to clear two sets of tracks AND the bottom pane....
I have attached a couple pix, should that be of any help!
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 03-19-2012, 07:33 PM   #2
DIY staff
Rewards Points: 7,174
First remove the bottom pane---then remove the top one after lowering it---
If it is a tilt in style---tilt bottom one first --then lower top one and tilt.
dougp23 (03-21-2012)
Old 03-19-2012, 08:02 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
The top sash tilts in the same as the lower. Rest the lower sash against the wall, then push the jamb-liners in again to release the upper sash. They can be a bit trickier than the newer models, sometimes they need a little "jerk" to pop them loose.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Old 03-20-2012, 07:57 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
It is made to tilt in. Just a bit trickier than the lower sash and requires a bit more maneuvering when you do it.
Old 03-21-2012, 07:16 PM   #5
Rewards Points: 348
Thanks everyone. I've been sheet rocking in my (non-existent) free time, my brain hurts! Then the wife asks me to tilt in the windows....
So easy once I read your hints and tried a few.
Thanks again.
Old 03-21-2012, 08:13 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
No prob.
www.HomeSealed.com
Old 03-22-2012, 08:20 AM   #7
Thanks again.
Send check to....
Old 04-03-2012, 09:53 PM   #8
Having same prob...not understanding solution
I have been working on this for several hours, found this thread, still don't understand. I'm hopeful someone can help me b/c the other person who posted figured it out!
My windows I'm struggling with are upstairs, so I can't reach the outside to clean. I was told that is why the previous owners put in these windows. I can tilt open the bottom pane easily. There are "sashes" (is that the right word?) that I push in towards each other while lifting the bottom window up, and then it tilts in towards me (I do this after unlocking the window).
However, there is nothing like this on the top panel, and I don't see anything on the top panel that looks like something that would allow it to tilt in.
There is a screen on the outside of the window...it only covers the bottom pane, but when I tilt in the bottom pane, I am able to move the screen up so that it covers the top pane, completely leaving the bottom pane open to the outside...if this makes a difference.
Any help would be greatly appreciated!
srogers18 is offline   Reply With Quote
Old 04-03-2012, 10:00 PM   #9
Rewards Points: 13,750
You really would have been better off posting your own question, not add onto some elses.
You may have a single hung window if someone cheaped out when buying the windows.
Old 04-03-2012, 10:10 PM   #10
Thank you...brand new to msg board, so I have now created my own thread. Thanks for guidance/suggestion.
Window pane replacement help dgbehrends Remodeling 17 11-19-2011 10:06 PM
Dual Pane Windows No Low E Glass and No Argon Gas Filling AZSun Windows and Doors 4 08-12-2011 09:10 PM
TDL-How to replace one broken pane? Jamboy Building & Construction 7 06-01-2010 02:06 PM
Clean oil off of tools, also clean the inside of a compressor capslock Tools 1 12-23-2009 11:36 AM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 07:42 AM
