Tiling Around A Window? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 09:46 AM   #1
Tiling around a window?
How big of a problem is a window In the shower?
hi2u is offline   Reply With Quote
Old 08-28-2012, 09:51 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,582
In vinyl, not too much. You will get condensation and hardware rust because of the moisture. You don't normally see the window that low because it is not intended to keep out that interior moisture and water will get into that wall assembly.
That window needs to be tempered per code as well so make sure it is or you are replacing it with one that is. Look into obscure options as well.
What is more immediately pressing is if you are are using that window? It looks racked and out of square based on the reveal along the bottom.
Old 08-28-2012, 09:55 AM   #3
Rewards Points: 14,312
Your going to get some mixed reviews on that question.
I just hate to see them in a shower, very prone to mold, wood rot and wall leaks.
Why would you want to see out or have someone looking in?
If you need the natural light remove the window, reframe, insulate and add a transome light at the top or install a solor tube in the ceiling if it's a one story house.
If your stuck on leaving it there then concider using acrilic block replacement windows and use all vinyl trim.
Windows on Wash (08-28-2012)
Old 08-28-2012, 10:26 AM   #4
I agree with Joe on this 100% for the record.
Great advice.
New replacement window problems iminaquagmire Windows and Doors 7 11-11-2011 11:56 PM
Tiling over lathe outside wall with window mkjeld Remodeling 0 10-25-2010 11:07 AM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
