Thinking About Retrofitting Vinyl Patio Door. Broken Glass. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-21-2016, 07:39 PM   #1
Rewards Points: 452
thinking about retrofitting vinyl patio door. broken glass.
Existing aluminum sliding door- was easy to replace broken glass.
Is it just as easy to replace broken glass in vinyl doors?
pman6 is offline   Reply With Quote
Old 02-21-2016, 07:41 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
Same basic principle with a glazing bead.
Old 02-21-2016, 08:43 PM   #3
dd57chevy's Avatar
Rewards Points: 986
Your post is a little cryptic . If I was as smart as W on W maybe I could understand .
The old 1.1 (?) R-value aluminum doors usually have a rubber gasket & screwed corners . The vinyl doors are usually on a foam tape or silicone adhesive with snap off glaze bead . Is that what you're asking ?
dd57chevy is offline   Reply With Quote
Old 02-21-2016, 09:40 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Take the door panel out and bring to a glass shop.
Coastal South Carolina
Old 02-22-2016, 03:31 PM   #5
Rewards Points: 452
damn, I forgot there's special glass. That must cost an arm and leg to replace the glass.
My rental property aluminum sliding door won't close properly anymore, and it gets a draft all the time.
If my tenants ever break the glass on the new door, oh boy.
thinking of installing a raised patio instead of a deck EPERRINGTON Landscaping & Lawn Care 2 03-09-2011 11:44 AM
Painting Vinyl Sliding Glass Doors IdahoBob Painting 5 01-05-2008 04:34 PM
Replacing regular glass with low-e in vinyl frame. Doug Crf Building & Construction 1 10-02-2006 06:31 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
