Which Of These "solid Core" Interior Doors Is The Best Value? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 10:16 PM   #1
Dave88LX's Avatar
Rewards Points: 564
Which of these "solid core" interior doors is the best value?
Have a trio of 30" x 80" bedroom doors to replace.
Lowes has free upgrade going on right now to "Safe N Sound" on their masonite doors. Cost: $75. They also sell Milliken Millwork PA door, $130.
Home Depot has Jeld-Wen's version of a solid core for $117 with their sale price.
All are 6 panel/flat jamb/brushed nickel hinges/identical optioned. If the Masonite is the best value, then great. I just don't want to buy junk (I know, look where I'm buying it from).
I will be in this house for at most one more year, FWIW. Then either renting it out most likely (darn market).
Thank you.
Dave88LX is offline   Reply With Quote
Old 03-01-2013, 06:07 AM   #2
Rewards Points: 150
Are they pre hung of just slab r u sure they t solid snd not hollow
kaschmid3 is offline   Reply With Quote
Old 03-01-2013, 06:56 AM   #3
DIY staff
Rewards Points: 7,174
I've installed many of the Masonite and Jenweld solid core doors over the years with good results---Not familiar with the third option----
I suggest you look over all three and see what the jambs are made of----you need to assess the quality / cost and make that call your self---sorry, I just never compared them side by side---
Old 03-01-2013, 09:38 AM   #4
Dave88LX's Avatar
Rewards Points: 564
Yep, pre-hung flat jamb solid core.
Old 03-01-2013, 09:39 AM   #5
Dave88LX's Avatar
Rewards Points: 564
The third option might just be a local option. Unfortunately I can't see either one without ordering them (I could see the hollow core, but not these solid ones). Good question, I'll take another look at the spec sheet and see what the jambs are made of. I just didn't know if one had an overall better reputation than the other (Reliabilt vs. Jeld-Wen).
Old 03-01-2013, 09:44 AM   #6
Rewards Points: 13,296
Why the added expence of a soild door if your just going to turn around and sell it?
There not likly to add to the resale value.
And why flat jambs, is the trim you have on the everything else that differant?
Just trying to grasp the big picture.
Old 03-01-2013, 10:09 AM   #7
Dave88LX's Avatar
Rewards Points: 564
I will still be living here for up to another year. Plus, who wants to listen to their 2 and 4 year old cry when they are put in their room?
Nothing special about the casing I have on other doors. The couple doors I have done, flat and split jamb, I found it easier to do the flat and add casing. The split jamb casings/jambs were pretty warped/bent. I don't know if that's normal or a fluke.
Not to mention, if Reliabilt is "good enough", then there is no added cost.
Old 03-01-2013, 12:26 PM   #8
DIY staff
I like the feel of a solid core bedroom door----I'm with you--split jamb doors look cheap---I prefer to choose my own trim---2 1/2" usually---better look and it hides the paint/caulk lines from the old casings----
Old 03-01-2013, 01:40 PM   #9
Dave88LX's Avatar
Rewards Points: 564
One other thing, I know it's more of a local thing I guess, but who would I look to for in-stock solid core doors? I'm looking at 3-4 weeks from the box stores.
Old 03-02-2013, 02:16 PM   #10
kwikfishron's Avatar
Rewards Points: 180
Don't know about "in stock" but my local lumber yard (not box store) can get me just about anything in a week or less.
kwikfishron is offline   Reply With Quote
Old 03-02-2013, 09:26 PM   #11
Rewards Points: 940
Don't walk away from the big box stores, run.
I have an old-fashioned lumberyard nearby and two others which all compete against each other.
They have a lot of door and jamb choices, as well as the hinges. They will make your doors up in 2 days and deliver to your site. I have had them deliver one door before and carry it in the house. I didn't have enough guts to ask the guy to carry it upstairs with me.
I learned that the 1 3/4" thick door is $5 more than the 1 3/8".
I think I paid about $114 for my last door, and it was a 2'-8" door.
Ask a salesman about the doors. On the jambs I got, you could choose between a solid wood with veneer, plywood, or particle board. And the veneer on the wall sides of the jambs are nearly 1/4". Little things like this make a big difference.
They also come wrapped up nice, and packaged with pieces of wood tacked on, holding them together.
cleveman is offline   Reply With Quote
Old 03-04-2013, 11:19 AM   #12
Dave88LX's Avatar
Rewards Points: 564
I can check with local lumberyards; I don't know any off hand. I will have to hit up the Googles Machine to see what I can find.
Called a few, nobody seems to stock them. PITA.
