Therma-Tru Door Installation Questions - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 11:37 AM   #1
I have a new pre-hung door that will be installed by a contractor (I'll assist) on a 35 year old house. I like to understand what needs to be done before starting. After reading the Therma-Tru install steps, I have a few basic questions:
The steps state:
- Are the framing and walls plumb?
- Is the opening square?
- Are the framing walls around the opening in the same plane?
- Is the subfloor level and solid?
And in each case, if not, then "Fix any problem now".
But given this is not new construction, I don't see how any of these problems can be fixed prior to just installing the door and shimming it as needed to assure it is plumb, square, in the same plane as the walls, and level on the subfloor (even if the subfloor is not).
So is there any way to address these possible issues, prior to placing the door and jamb in the rough opening and shimming as needed?
thanks,
jdbs3 is offline   Reply With Quote
Old 10-23-2013, 12:59 PM   #2
Rewards Points: 12,856
Sure is.
Nails in the top or bottom of the studs can be cut and the stud adjusted so it's plumb.
Floors can be jacked or leveling compound used under where the threshold sits.
Should not matter if the header is off as long as the door fits.
The rest is just a matter of shimming.
Old 10-23-2013, 01:52 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Solid advice from Joe, although moving the studs can be easier said than done when the drywall/plaster is screwed into them already. For the most part jdbs, getting the door plumb and level is done through shimming as you figured (and as Joe also said).
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 10-25-2013, 10:33 AM   #4
jdbs3,
Feel free to contact us with any questions you have. You can reach customer support 8:00 a.m. to 6:00 p.m. EST Monday through Friday at 1-800-843-7628 (1-800-THERMATRU) or reach us by email by going to this link: http://www.thermatru.com/customer-su...t-us/form.aspx
Thank you, Therma-Tru Doors.
TT Doors is offline   Reply With Quote
Old 10-25-2013, 10:55 AM   #5
747
registered
747's Avatar
Rewards Points: 534
I prefer to take the door out of the jamb before installing. Square the jamb and level it. You should be ok. You check for square by taking a diagonal measurement from outside of the jamb. If they don't match. The door needs to be lifted with a shim a little. (on this side only).
747 is offline   Reply With Quote
Old 10-25-2013, 12:14 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 710
No offense 747, but that can be very tricky. I don't believe that I've ever met a professional that does that (except in some extraordinary circumstance), I would not advise it.
www.HomeSealed.com
Old 10-29-2013, 03:02 PM   #7
and
My existing threshold is bowed in the middle, so it will be replaced. Easy enough to assure this is level. As noted, the header is a non-issue.
But if the studs are not plumb, then just cutting the nails still may not allow for adjusting the jacks/kings. From my perspective, it may come down to "it is what it is" and compensate for it when shimming the jamb.
Thanks for the feedback all.
jdjd is offline   Reply With Quote
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 09:38 PM
Mobile Home Carpentry questions immeraufdemhund Carpentry 3 11-19-2010 07:52 AM
Newbie with questions about a 4 ton rheem nissan4x4 HVAC 4 05-25-2010 12:53 AM
A few roof questions before I begin... chrisexv6 Roofing/Siding 6 05-02-2010 07:16 AM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
