-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Temporary Window / Door (http://www.diychatroom.com/f104/temporary-window-door-109106/)
FireLlama77 06-28-2011 08:42 PM
I'm renting a condo where the master bedroom is a loft with a large opening overlooking the living room. The staircase up there also doesn't have a door. For noise reasons (my roommates stay up very late) I'd like to plug up the hole with something as sound-proof as possible, and get some kind of door in the stairs. I custom fit some pieces of insulation in the window and have a curtain in the stairs for heat purposes, and while they provide privacy, they block zero noise. Any option needs to be completely removable when I move out with no permanent damage. Thanks ahead of time for any suggestions.
Stanchek 06-29-2011 10:19 PM
Hmmmm, just thinking about foam insulation board. Easy to cut to any shape, super light weight, inexpensive. Sandwich as many pieces together as you want, that will stop the noise from the opening. Hell, you could also make a cheapo door type thing out of it. Just a thought.
FireLlama77 06-30-2011 05:24 PM
I was thinking that if I can't find enough rigid foam, I could glue 2 layers on either side of some plywood. That would probably help block more sound as well. The stairs are very skinny and right next to a hallway, so I was thinking of someway to make the door go... straight up. But it would be tough making something that wouldn't rub paint off the wall but still seal to block noise. Maybe foam is the right answer again...
Stanchek 06-30-2011 05:49 PM
Go to lowes or home depot, they have stacks of 4x8 sheets of foam board. Hell, glue six of them together.
oh'mike 06-30-2011 05:55 PM
Post a picture---Building a removable partition with a door is not such a difficult job---but to get decent suggestions we need to see the area.---Mike---
FireLlama77 07-01-2011 12:04 AM
The window is approximately 10' x 2.5' and the stairway is 2.5' wide and about 8' high. Here are some pictures:
http://img839.imageshack.us/img839/3844/dsc00035gf.jpg
http://img87.imageshack.us/img87/9381/dsc00036za.jpg
