Tempered Glass Requirement - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 08:23 AM   #1
tempered glass requirement
in a multi-storied bldg at the floor lines is it ok to just temper the inboard lite of an insulated glass unit?
Rick Humphries is offline   Reply With Quote
Old 12-13-2011, 09:01 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Where i'm at anything below 18" must be tempered.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-13-2011, 12:09 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,676
18" from the walking surface is just part of the code.
It also needs to be larger than 9 sq/ft, top edge is higher than 36" from the walking surface, and withing 36" of a walking surface.
Tempered Glass
Old 12-13-2011, 03:37 PM   #4
Registered User
Rewards Points: 5,516
Welcome to the forums!
Is the glazing in a door? http://publicecodes.citation.com/ico...008_par005.htm
Where is it located? http://publicecodes.citation.com/ico...008_par006.htm
Is this a residence or commercial building?
Sent from a Toshiba Satellite laptop
Gary
Need tempered glass clarification Red Oak Building & Construction 2 09-01-2011 11:20 AM
Tempered or regular glass for tables? Sliding Man Interior Decorating 5 05-15-2011 05:16 PM
Tempered Glass requirement Larry Inmon Building & Construction 1 05-06-2011 01:22 PM
type of glass (tempered, laminated, etc.) myrtal Building & Construction 3 08-14-2010 08:03 AM
Tempered glass needed or not? DangerMouse Building & Construction 5 04-29-2010 06:34 AM
