Taking Out A Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-16-2013, 11:54 AM   #1
Rewards Points: 95
Taking out a window
I am going to be replacing some old single pane aluminum insert windows with new replacement sash kit. Why am I just doing the sashes? The original wood window frames are still in good condition other than needing a good scrape and paint job. The alum. inserts are crappy and loose and I have never liked the looks of them. Installing the new sashes and jambliners shouldn't be a problem. I cannot figure out how the old windows are installed. I can't find any markings anywhere indicating what brand and I don't see any screws in the sides or top.
I am thinking it is attached just by silicone maybe and I can pull it out once I have the stops out? And from everything that I can tell it IS an insert and is not nailed to the outside of the house by a flange. Hopefully someone will have an idea. If not, I will just have to push, pull, and yank until it comes out Thanks in advance!
Centex2011 is online now   Reply With Quote
Old 03-16-2013, 07:05 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Very difficult to tell by the pics, but 9 out of 10 aluminum windows that i see have a nailing flange. Generally not the easiest extractions, so be prepared. The one thing that I can say nearly for certain is that they are NOT simply held in by silicone. If you are lucky and there is no flange, there would still be fasteners in the jambs.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-16-2013, 09:56 PM   #3
Rewards Points: 13,276
Sometimes it's just staples holding it in.
Sort of looks like one in one of the pictures.
Old 03-17-2013, 12:03 AM   #4
Man of many hats
wrangler's Avatar
Rewards Points: 354
If you can not find any fasteners in the aluminum jamb, it is possible that they just replaced the original wood windows with the aluminum inserts and the only thing holding them in is the caulk and the wood stops(trim) that you show in your pictures on the inside. In one pic it even looks like it has been removed before?
Man of many hats
wrangler is offline   Reply With Quote
Old 03-17-2013, 12:35 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,874
Looks like they could be inserts by the aftermarket looking stops.
Any pictures of the exterior?
Old 03-18-2013, 11:33 AM   #6
Rewards Points: 95
Sorry it has taken s couple days to respond. We had my mother-in-law in town and wasn't able to do much.
Wrangler, that is what it seems like to me. I went outside to see if there was anything visible that I missed the first few times I inspected the windows and there is nothing. The only thing I see holding the window in place is the ext. stop trim (red line in photo) and a filler piece (green line in photo) that they used to fill in the space where the original wood window track was (I'm basing that on how the few original windows left look).
And the interior trim stop had been removed previously... by me. I had to remove them to get an accurate measurement for my replacements.
Old 03-25-2013, 10:59 AM   #7
Rewards Points: 95
Well, we replaced the window this weekend and the old window came out fairly easy. There were no screws, clips, or anything else holding it in but caulk and the trim. We took the interior stops off, cut the caulk and paint from around the outside of the window and pushed from the outside and out it came. The only thing we had to do was shimmy it a little to get past some old caulk between the top of the insert and the frame. I was expecting it to be a pain to get out and take us a while, but it went pretty quick. Three more to go for that room plus 21 others. Woohoo
Old 03-25-2013, 12:52 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Well, it worked out well for you as far as getting them out... Still blows my mind how poorly some folks installed them in the first place. Truly a "caulk and walk".
www.HomeSealed.com
Old 03-26-2013, 08:03 AM   #9
If a little caulk is good...isn't more better...?
Glad it worked out for you Centex.
Post up some before and after pictures!!
Old 03-26-2013, 11:42 AM   #10
AHH, SPANS!!!
Rewards Points: 1,166
it helps to back caulk the stops when re installing them. that means, run a bead of caulk to the back edge of the stop before placing against new window insert. you should see it smoosh out a little toward the interior of the stop and insert, just pull that smooshed amount with your finger and let it cure for a few days and then come back and caulk the stop to the the insert like normal before painting. that is a way to get a better seal around the edges of the windows. use a quality caulk, to many times I've re worked pieces and parts on houses where cheap caulk was used and it was either as hard as concrete with zero flex or it was crumbling off of the walls, so a good quality caulk is well worth the extra money.
hand drive is offline   Reply With Quote
The Following 2 Users Say Thank You to hand drive For This Useful Post:
Centex2011 (03-26-2013), Windows on Wash (03-26-2013)
Old 03-26-2013, 01:14 PM   #11
Rewards Points: 95
Thanks hand drive. I will keep that in mind when I am buttoning everything up.
I don't really have before and after, but I will take a side-by-side shot this evening- new next to old yet to be removed. I installed just one before I spent a lot of money on something that wouldn't work... always hesitant when spending a big chunk of change
Old 03-26-2013, 09:08 PM   #12
Rewards Points: 95
Here is a photo of the new window. I have painted the windows, I just need to paint the trim (interior and exterior) so please ignore the poor condition of the paint. It will be remedied shortly.
This is a pic of another set of windows that looks just like a before shot of the window I replaced. I personally believe the new windows, once in, will change the look of the house, despite the fact that the whole house needs a new paint job, and ultimately new siding
Old 03-27-2013, 08:52 AM   #13
Looking good.
Keep up the good work!!!
Old 03-27-2013, 06:47 PM   #14
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1. Get that trim fixed up and you'll be in business
www.HomeSealed.com
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 09:41 AM
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 02:48 PM
New replacement window problems iminaquagmire Windows and Doors 7 11-12-2011 12:56 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 10:30 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
