#1 |
Landlord
Taking the old window(aluminum) out for installing new construction windows
took the casing down, do I have to destroy this wood to put in the new window?
#2 |
Windows & Remodeling
That is the jamb extension that I referred to in the other thread... As I mentioned, it depends on 1) if it is attached to the existing window, and 2) what the jamb depth of the existing window is. If it is less than 3 1/4", you will need that either cut-back (ripped down) or replaced as the new window will sit in farther. Another option would be to shim the new frame out, but that present a host of other challenges.
An alternative method would be to down-size the window and get no nailing fin, and install it inside that wood, essentially using it as a buck frame like a replacement window wood... That method would cause you to lose some glass area and also necessitate adding stops to the interior (typically shoe or cove) as well as some professional metal-work on the exterior to get everything flashed properly.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by HomeSealed; 12-06-2012 at 02:25 PM. |
| The Following User Says Thank You to HomeSealed For This Useful Post: | Windows on Wash (12-06-2012) |
#3 |
Landlord
Jesus, and I was just going to replace the bottom brick mold today...looks like I will be buying a window, some siding, and some more brick mold
| Display Modes | |
| New construction windows in a remodel | MrTique | Building & Construction | 5 | 12-02-2007 09:52 AM |
| Replacement or New construction windows if....... | kgressler | Remodeling | 4 | 11-06-2007 02:04 PM |
| Flashing for New Construction Replacement Windows in Stucco House | BigJimmy | Building & Construction | 10 | 11-03-2007 01:48 PM |
| How to measure windows for new construction? | pastrami | Remodeling | 1 | 04-26-2007 08:36 PM |
| How do I install new windows? | RickT | Carpentry | 17 | 10-12-2006 07:06 PM |
