Taking Clad Double Hung Apart To Create Smaller Fixed Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 01:13 PM   #1
Taking Clad Double Hung apart to create smaller fixed windows
This is my first visit/post here, so I may not be starting out correctly.
I've got a metal barn behind my house that i'm converting into heated space. I've been visiting salvage houses for materials and i'm getting near the window stage at this point. I've found some bronze, aluminum clad, double hung windows that will be perfect for certain areas. I've been hoping to find a couple of large, fixed, horizontal windows for a specific area in the front of the barn. I haven't had any luck so far, nor do I think I will. Here's what I would like to do, but I'm not sure it's possible.
There are plenty of matching double and single hung windows that complement the others that I have purchased already. Can I take either a double or single hung and remove the framing completely to have two, separate insulated glass, divided light, fixed windows...from each previous set? My thought is that I would buy three matching double or single hungs and end up with 6 matching, smaller fixed windows. I could then frame those in as two sets of three windows each, with some simple framing between each window.
My concern is, how challenging is it to disassemble an aluminum clad window to end up with the two, smaller pieces.
Thanks for your help!
KJinCton is offline   Reply With Quote
Old 10-07-2013, 03:48 PM   #2
Rewards Points: 2,238
Well, not knowing the exact windows you're talking about -
Take apart aluminum-clad windows and use them as single units?!?
No fun at all!
Good luck!!!
rossfingal is offline   Reply With Quote
Old 10-07-2013, 04:26 PM   #3
Rewards Points: 13,752
And going to be sure way to have leaks.
smaller new exterior windows hohadcr Remodeling 11 06-25-2012 12:07 AM
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 12:39 AM
Replacement Windows Smaller Than Rough Opening stubits Remodeling 1 08-25-2010 06:19 AM
Can't open Milgard Aluminum Single hung windows riverjamie Building & Construction 2 01-19-2010 05:15 PM
