Taking 4 Inches Off Prehung Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-05-2014, 07:49 AM   #1
Rewards Points: 34
Taking 4 inches off prehung door
Hi all. What would the best way to take 4 inches out of a prehung door be? I have two doors that need to go under a soffit, one 30 inches wide and one 48 inch french door. Both hollow core.
untilcomplete is offline   Reply With Quote
Old 03-05-2014, 08:00 AM   #2
Rewards Points: 1,702
Carefully cut 4" off the top using layer of masking tape on the cut line to prevent panel splintering/tear out. Save the solid wood end from the cut off. Take out at least the solid end amount of the torsion box honeycomb cardboard material and insert the solid wood cut off back between the panels and stiles where the cardboard was removed. Elmer's glue will be proud of you and plenty proud to hold that piece glued back in to look like new.
Old 03-05-2014, 08:10 AM   #3
Rewards Points: 144
I don't know about taking it off the top?Depends on the door.I have had to do this on a few occasions and prefer to take it off the bottom.Less noticable.(sp) Depends on the style of door.Never a great solution and does not look like new but can be done.Use a straight edge when cutting.
mako1 is offline   Reply With Quote
Old 03-05-2014, 08:12 AM   #4
Rewards Points: 276
Also remember to leave your 1 inch gap under door. If your putting in 3/4 plywood or thick carpet you may want to leave more. You dont want to cut it twice.
I like to install doors after flooring has been installed cutting around door jambs is a pain.
JustinK is offline   Reply With Quote
Old 03-05-2014, 08:14 AM   #5
They seem to be going under a soffit is why I recommended the top.
Old 03-05-2014, 08:33 AM   #6
Rewards Points: 14,026
And what good would it do to cut off the top of the door? There would be nothing left of the rail, the whole jamb and casing would have to come apart
Are these raised panel or flat panel doors?
I would have started with a mobile home door which is 78" tall and then remove 2" from the bottom, instead of 4", which is going to weaken the door and throw off the whole look.
Even a solid door would have been a better choice.
Old 03-05-2014, 08:34 AM   #7
Rewards Points: 276
I wouldnt talk it off the top either. Its alot more noticable. There will only been like an inch left of the top raised panel.
Old 03-05-2014, 10:05 AM   #8
Hopefully the OP will understand that the rail that was cut off will be re-used after it is cleaned and it will fit perfect.
Old 03-05-2014, 10:31 AM   #9
Rewards Points: 34
Thanks, I am tracking on the reusing the rail.
Old 03-05-2014, 10:42 AM   #10
Rewards Points: 2,428
I think that I might cut the 4 inches in half , 2 at the top and 2 at the bottom. You will still need to reuse the top and bottom rail.
This way it looks more symmetrical. but twice the work.
ED
de-nagorg is online now   Reply With Quote
Replacing Prehung Front Entry Door in Stucco a1481155 Windows and Doors 13 09-04-2013 05:11 PM
rough framing for an exterior door (not prehung) measurement question graysqwrl Building & Construction 5 08-15-2011 08:51 PM
Installing a Home Depot prehung interior door. John58 Building & Construction 4 10-31-2010 07:20 PM
Prehung Interior Door ranapratab Carpentry 2 10-30-2009 12:48 PM
Prehung Door install problem bscj@innernet.net General DIY Discussions 3 04-08-2008 10:40 PM
