Switching From In Swing To Out Swing Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-21-2013, 04:42 PM   #1
Rewards Points: 590
switching from in swing to out swing door
I have a really small laundry room with an exterior door in it that opens in like most exterior doors do. This door is a big nuisance, especially when I replaced my washer and dryer since I had to take it down to get the new ones inside. Anyway, we now have a deck that extends past that door and it would be much more convenient to replace it with an out swinging door. How big of a project is this and should I not even try it and just hire someone?
nikeman is offline   Reply With Quote
Old 09-21-2013, 05:05 PM   #2
Framing Contractor
Rewards Points: 120
That will require some intermediate DIY skills. What kind of siding is on the house? What is the age of the home? You will have to replace the door, frame, and trims. The outswing door will be a special order item and will set you back several hundred dollars if not more. Posting some pics would be helpful too.
sixeightten is offline   Reply With Quote
Old 09-21-2013, 05:22 PM   #3
Rewards Points: 2,238
Hire someone!
rossfingal is offline   Reply With Quote
Old 09-21-2013, 05:31 PM   #4
Rewards Points: 590
I'm aware that they are special order and are expensive since I bought a double outswing door for my shed a couple years ago. I'll just hire someone. Lol. I have to many projects to do anyway.
Old 09-21-2013, 06:29 PM   #5
DIY staff
Rewards Points: 7,174
The difficulty is determined by the outside trim and siding---
Most doors have wood brick molding on the outside---If that is the case---the job is not to bad---You may need to make up some special trim if the brick molding is wider than the existing---
Post a picture from the outside----This is intermediate level work,as sixeightten mentioned---seldom will a job like this turn into a complicated nightmare---
Old 09-21-2013, 07:22 PM   #6
Rewards Points: 13,732
My local Home Depot stocks outswing doors.
There were all flat jambs, (no brick molding) but that's a good thing because I only us PVC brick molding anyway.
oh'mike (09-21-2013)
Old 09-22-2013, 08:37 AM   #7
Rewards Points: 590
Here's the door. It has a large threshold at the bottom. Taller than any other door on the house.
Old 09-22-2013, 09:40 AM   #8
DIY staff
Measure the height of the door ---from the bottom lip of the threshold to the top of the jamb---that will be about an inch above the face of the jamb---the brick molding is nailed to the face of the jamb---and will be about 1 1/4" wider than the jamb-
pocket flipper kit for room doors? anuvanoob Carpentry 9 01-06-2016 09:13 AM
laundry chute - how do I get the door to swing back freely and rest in line MLMIB Remodeling 3 10-09-2012 12:31 AM
interesting patio door problems....please help. diybrad Building & Construction 6 11-20-2011 11:52 PM
I bought a New Front Door, but wrong swing... Fisher252 Windows and Doors 8 06-09-2011 10:58 AM
Security screen door dangerp Carpentry 4 09-22-2010 07:02 PM
