Switch Lever From One Side Of Door To The Other - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 04:35 PM   #1
Exclamation
Switch Lever from one Side of Door to the Other
Just installed Schlage F51 flair lever style door handle to interior door to garage. As you can see in picture the lever is upside down. Set comes with a tool - also in pic - which is used to remove just the lever so they can be switched from one side to the other side of the door so then the levers would be right side up. Removed one handle without a problem. Other handle refuses to budge. The tool included is a pin about 3 inches long with a loop on one end. Insert the pin in the hole, depress the "thingy" and the handle slides off. No matter how hard I push on the other side the handle will not budge. I don't feel like the "thingy" is being depressed at all. Very frustrating. Hardware store closes early on Sundays so couldn't take it back to exchange it. Called the help line but they don't work on Sundays. Went to the Schlage web site but every time I click on something it takes me to a page with an error message. Fortunately the door levers open the door but it doesn't feel right. Any ideas? Suppose I'll take it back next weekend if I can't fix it. What a pain!
joek201 is offline   Reply With Quote
Old 03-25-2012, 05:53 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
It looks to me by your pic that you have the wrong lock set. If you flip that handle the way it is now it will extend passed the door?
If you really want to do that,take the 2 screws that hold the handle together out flip the handle and put it back together.
sublime2 is offline   Reply With Quote
Old 03-25-2012, 06:48 PM   #3
Thanks Sublime. I figured this out finally and was about to edit the post when I saw your reply. Sorry if I wasn't clear but I wanted to flip the handles from one side of the door to the other so the flair is pointing down. But I couldn't get the handle off the side with the lock mechanism. After looking at a PDF of directions with actual words on them from another site did I realize I had to use the key in the lock in order to remove the handle. Which makes sense if you think about it otherwise a robber could potentially take the thing apart and get inside.
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 09:58 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
