Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-01-2012, 07:13 PM   #16
In-swing vs out-swing door. Can they be reversed?
If I turn the threshold it will leave an inch gap. I can just get that rubber strip that screws to the bottom of the door if it becomes an issue.
mikegp is offline   Reply With Quote
Old 10-01-2012, 09:43 PM   #17
Windows & Remodeling
HomeSealed's Avatar
I'd order the proper door. You are just asking for problems with an improper installation.
HomeSealed is offline   Reply With Quote
Old 10-01-2012, 10:27 PM   #18
I actually just mocked it up and I'm thinking I might install it the correct way. The area under my stairs is bigger than I thought so having it swing in might not be so bad. I appreciate everyone's help.
The Following 2 Users Say Thank You to mikegp For This Useful Post:
DangerMouse (10-02-2012), HomeSealed (10-01-2012)
Old 10-01-2012, 10:32 PM   #19
HomeSealed's Avatar
That would be ideal Mike: the best of both worlds.
Any thoughts on hanging a foot pedal on porch swing? tabatt07 General Discussion 1 07-25-2012 05:54 PM
Will this vertical-posts Swing set plan work? diy_in_md Building & Construction 14 10-15-2011 11:06 PM
Porch Swing nikeman Building & Construction 21 03-07-2011 08:15 PM
GFCI tester shows hot/ground reversed, then not reversed bw777 Electrical 7 02-04-2011 10:16 AM
hot / neu wiring reversed, getting a shock PIGEONS Electrical 2 11-07-2010 06:43 PM
