Sweaty Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 11:11 AM   #1
Sweaty windows
The house I just bought has what I call jalousie windows; they crank open. They aren't the typical jalousie type with narrow slats of glass, they each have 3 large panes about 14x32 inches, with removable screens and storms on the inside. My issue is that they sweat like crazy, to the point where water actually puddles on the sills. Short of replacing them, is there any way to prevent this?
bpress54 is offline   Reply With Quote
Old 11-24-2011, 01:11 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
Reduce the indoor humidity levels, crack open the exterior window slightly so that the humidity that leaves from the interior space can dry to the exterior and get some convective air movement, and/or seal up the interior storm a bit better.
Old 11-24-2011, 03:18 PM   #3
Sweaty windows
Thanks, I'll try it.
Old 12-02-2011, 09:14 PM   #4
Rewards Points: 5,336
Doubtful. These are probably the worst windows to have.
Possible solution would be to add another solid layer of plastic or glass to stop air transference.
Ron
B. Franklin 1759
Old 12-02-2011, 09:41 PM   #5
Rewards Points: 12,808
I agree with those are the worst windows to have there sweating for two reasons one the humitys to high in the house, but also the windows are cold. They all leak air, the cranks break, a driving rain will let water in, most have dead flat sills which allows water into the walls from leaks.
There called casment windows.
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 11:46 PM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
