Stucco Adhesive - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 12:35 PM   #1
Rich J
stucco adhesive
Besides not having a lot of money to spend on fancy gadgets, such as window screens, I feel like Iím broke. Most of the time! I have done very well without screens for the past several years, but now my girlfriend wants me to install them!
I have an old roll of silver duct tape, which sticks to most surfaces pretty well. I have a new roll of red stucco tape, which barely sticks to stucco. And I have nylon screen material. I also have blue painterís tape and ĎStrong Stikí by DAP. I have not yet opened either of these.
Using the new red tape, I put the kitchen screen up twice on Saturday. And it came down again Saturday night.
Other than buying fancy expensive wood or aluminum screens, how can I get the screening material to stay?
Thank you.
20rdj04 is offline   Reply With Quote
Old 05-15-2011, 12:45 PM   #2
Window and Door installer
Well... Screening kits really aren't that expensive, but assuming those are still out of your budget, I'd probably try something more in the area of staples. If you have alum windows and stucco maybe put some small nails around the frame and stick the screen mesh on those?
Be creative?
Jkslate is offline   Reply With Quote
Old 05-16-2011, 08:42 AM   #3
Rewards Points: 5,336
Thank you.
I think by "install", she wants something a little more elaborate then duct tape.
Do you own any tools? It would help a lot if you owned a few tools.
Tape measure, saw, screw driver and a staple gun would do the trick.
Ron
Old 05-16-2011, 08:32 PM   #4
My local handiman has suggested that I use pvc pipe as a frame. My apparent problem w/ that is that it does not stay straight on top, it sags. Can you offer me a solution? Or are you Mr Critic, too?
Thanks for nothing!
Now see.. If you can afford PVC pipe and 90 degree turns for it to build a frame with that, you could easily pick up a screen kit from homedepot.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
84" of screen frame for under $5
http://www.homedepot.com/buy/tools-h...ler-14995.html
The mesh/spline/roller for $25
You could do most of your house for under $50 probably. If I offended you with my nails/staple comment its because I figured if you couldn't afford to actually screen your home, then you really couldn't afford ANY type of "alternative solution".
edit: That being said, like Ron said, if you don't have the basic tools to assemble the screen kit (saw, tape measure) it might be more difficult.
Old 05-17-2011, 05:28 PM   #5
Rich J
stucco, adhesive, screening
Your suggestion of corners sparked the idea of vertical spreaders in the middle of the window, where the window is divided anyway.
Thanks very much.
Tags
screen , stucco
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 05:58 PM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 06:38 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 01:22 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 04:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
