01-06-2013, 12:09 PM
#1
striker plate
how does a guy properly line up a striker plate ? every time i try, it doesn't go well. though i end up getting it done, the end result is not the greatest.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
01-06-2013, 12:17 PM
#2
The Token Engineer
striker plate
Several layers of masking tape and close the door,the indentations will show to mark the plate. Do screws first, drill holes, remove tape and mount plate, mark with pencil and remove, recess plate.
01-06-2013, 01:46 PM
#3
Average Joe/ex-Navy IC3
striker plate
Even more fun, when the holes are already pre-drilled in the door frame.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
01-06-2013, 03:13 PM
#4
striker plate
Is this a door frame your trying to make or is it a prehung that's just a little off?
For one I'm making I just close the door until the latch just touches the jamb and mark the top and bottom.
01-06-2013, 10:13 PM
#5
striker plate
it is repairs to a damaged jamb. i shut the door with the latch out, then mark the heights. but the problem comes when setting the striker to hold the door tightly closed. is either to tight, or to loose.
i think next time i am going to put tape on the jamb. then a little paint on the latch. push door fully closed and release the knob. this will mark the tape.
01-07-2013, 02:08 AM
#6
striker plate
lipstick on the latch marks well.
01-07-2013, 10:30 AM
#7
gravity always wins
striker plate
I always use a footrule with the slide extension. (The slide that is used for measuring inside dimensions) I mark the the jamb for the latch height, then close the door and extend the slide against the latchbolt (between the door and jamb). Then slide the wooden part of the rule against the edge of the jamb. Pinch the slide tight so it doesn't move and open the door. Now place the wooden end of the rule against the jamb and mark a line at the end of the slide on the jamb where the latchbolt fell.
01-07-2013, 11:19 AM
#8
STAFF
striker plate
If it is too loose some strikers have a slot on the tang that goes into the hole you drilled, take a screwdriver and put in the slot and bend the tang just a little at a time until the door is tight.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
01-07-2013, 10:51 PM
#9
striker plate
thanx guys ! good ideas...
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
