Stricker On My Deadbolt Broken - In Locked Position? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 08:03 PM   #1
Stricker on my deadbolt broken - in locked position?
My deadbolt is crumbing as I tried to fix it today. Learned that the stricker is broken, therefore, it will not turn to open the deadblot w/a screwdriver.
How do I get that deadbolt to open...grrrr!
Nancy P is offline   Reply With Quote
Old 10-13-2012, 08:12 PM   #2
Rewards Points: 13,300
Remove the two screws holding the lock part together and remove it, you should be able to reach inside and move it out of the way with a flat screwdriver.
Old 10-13-2012, 10:09 PM   #3
Not optimum, but worst comes to worst get an angle grinder, stick it into the edge between door and frame, and cut the deadbolt in half. Or, you could try to demolish the latch assembly from the hole in the door enough to pull the bolt out. Either way, you might have some damage to the surrounding areas.
Have you tried lubricating the latch mechanism and then really putting some torque on it?
AZJefe is offline   Reply With Quote
Old 11-19-2012, 08:34 PM   #4
Samsung SCX 4729 Вот купила ....
I bought a copier - samsung scx 4729, cartridge prints and what do I do ?
see here - Samsung SCX 4729 Перепрошивка и
Advise, can anyone come across? Cartridge so expensive! Where to find cheap ink cartridge for samsung scx 4729 ? Прошивка и samsung scx 4729
ML Hyosaax is offline   Reply With Quote
Double Keyed Deadbolt Lock stuck in locked position hubbard Building & Construction 17 07-23-2012 03:28 PM
Aluminuim back door lock stuck in the locked position Peter davis Windows and Doors 2 07-15-2012 12:45 PM
Deadbolt Locked indicator luweee Electrical 6 06-13-2010 12:32 PM
broken deadbolt misterdunkirk General DIY Discussions 23 12-18-2007 09:04 PM
