-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Stricker on my deadbolt broken - in locked position? (http://www.diychatroom.com/f104/stricker-my-deadbolt-broken-locked-position-159962/)
Nancy P 10-13-2012 08:03 PM
My deadbolt is crumbing as I tried to fix it today. Learned that the stricker is broken, therefore, it will not turn to open the deadblot w/a screwdriver.
How do I get that deadbolt to open...grrrr!
joecaption 10-13-2012 08:12 PM
Remove the two screws holding the lock part together and remove it, you should be able to reach inside and move it out of the way with a flat screwdriver.
AZJefe 10-13-2012 10:09 PM
Not optimum, but worst comes to worst get an angle grinder, stick it into the edge between door and frame, and cut the deadbolt in half. Or, you could try to demolish the latch assembly from the hole in the door enough to pull the bolt out. Either way, you might have some damage to the surrounding areas.
Have you tried lubricating the latch mechanism and then really putting some torque on it?
ML Hyosaax 11-19-2012 08:34 PM
Samsung SCX 4729 Вот купила ....
I bought a copier - samsung scx 4729, cartridge prints and what do I do ?
see here - Samsung SCX 4729 Перепрошивка и
Advise, can anyone come across? Cartridge so expensive! Where to find cheap ink cartridge for samsung scx 4729 ? Прошивка и samsung scx 4729
