Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-13-2011, 06:52 AM   #1
Strengthening Garage Doors
I have a 2-car wide garage door. I was looking to make it stronger, especially in high wind loads. Is there a way to install metal bracing across the sections to strengthen the door or would I have to buy a completely new garage door?
JackOfAllTrades is offline   Reply With Quote
Old 09-13-2011, 07:26 AM   #2
Super Moderator
What is the door made of? That will determine if you can stiffen it up or not.
Old 09-13-2011, 07:42 AM   #3
Exterior Construction
Windows on Wash's Avatar
If it is a builder's grade door (single panel aluminum) you could ad bracing or foam to it.
Old 09-13-2011, 07:56 AM   #4
You could add those "U" braces like the one at the top for the opener, at each section. You will have to readjust the springs to compensate for the weight. Might seem a bit clunky, but way cheaper than a new reinforced wind rated door.
Old 09-13-2011, 08:54 AM   #5
"Nail-Bender"
Yes - what "Just Bill" says.
Remember - playing with the springs on a garage door can be
very, dangerous!
roossfingal
rossfingal is offline   Reply With Quote
Old 09-13-2011, 09:50 AM   #6
+1
Be very careful with the springs. I nearly got one right across the face. That would have left a mark.
The Following User Says Thank You to Windows on Wash For This Useful Post:
rossfingal (09-13-2011)
Refinishing Garage Doors with Sikkens Cetol 123 AustinPainter Painting 0 08-28-2011 01:54 PM
amarr garage doors rfhjr Building & Construction 0 02-24-2011 06:41 AM
Painting Old Wood Garage Doors DIYnewbie2 Painting 4 05-14-2009 07:11 AM
Swinging Garage Doors Justin08 Carpentry 1 11-16-2008 11:59 AM
