Strange Door Knob With No Visible Screws - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 12:29 AM   #1
Strange door knob with no visible screws
Lots of search results on the Internet tell you how to remove an old door knob. None of them tells you how to proceed after you remove the knob itself, then the circular decorative cover and you are left with a second, thicker cover, with 2 holes but no screws:
Any suggestions?
ChristianC is offline   Reply With Quote
Old 03-28-2012, 12:55 AM   #2
DIY Enthusiast
sublime2's Avatar
What I think your describing is like a commercial knob. ( no pic) once you remove the knob and cover,the thicker ring twists off like a screw.there are no screws that hold that type of knob together I believe.
sublime2 is offline   Reply With Quote
Old 03-28-2012, 08:48 AM   #3
Window and Door installer
Most likely there is a slot somewhere on the sheath that has to be depressed in order for the knob to be separated. At home, a finger nail file tip is a good item to push into the slot. Wiggle the nob while pressing into the slot and you'll usually get some separation. Otherwise, it's possible the face plate (item with the two screw holes) could come off to reveal additional screws.
Jkslate is offline   Reply With Quote
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 08:34 PM
Remove door knob - no screws visible ? Sliding Man General DIY Discussions 21 05-19-2011 09:31 PM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 09:56 AM
switchplates with no visible screws Yoyizit Electrical 2 01-17-2009 10:58 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
