Storm Leaks From Driving Rain - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-19-2013, 07:50 PM   #16
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Making sure that you flash the head properly. Did a similar one recently that was a chronic leaker. We actually took off the gutter, fascia, and a few rows of shingle so that we could run water and ice behind and lap everything properly from the roof all the way down. Probably overkill, but I dont like call backs
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
gregzoll (11-19-2013)
Old 11-19-2013, 10:00 PM   #17
Rewards Points: 6,652
What about placing overhangs over the windows for right now, to help let the water flow over away from the window. I know that it is a temporary band-aide, but it would keep it from driving against the top and going down behind the siding.
Old 11-20-2013, 12:25 PM   #18
bryanp22's Avatar
Rewards Points: 300
Last night I checked the gutters and they were full of leaves. So I cleaned them and I'm hoping that was my issue and as long as they stay clean water running down won't be a issue. I don't think I want to mess with a overhangs as I have very limited clearance beneath the gutter. We are looking a getting our siding replaced as it's aluminum that is showing its age next year hopefully.
bryanp22 is offline   Reply With Quote
Old 11-20-2013, 02:19 PM   #19
Get larger gutters when you do the siding, along with repairing any fascia boards that are rotted along the gutters. When you get the gutters, get the shields that go over to keep the leaves out, but lets only water into them.
Old 11-20-2013, 02:20 PM   #20
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Sounds like a good plan Bryan. Just be sure to keep an eye on things through winter.
www.HomeSealed.com
Old 11-20-2013, 02:57 PM   #21
bryanp22's Avatar
Rewards Points: 300
The flashing the gutters are attached to was just replaced with new aluminum when I had the roof done. They also added three feet of ice shield at the bottom. I looked at the flashing above the window last night and I think with the amount of leaves that were in the gutter and the volume of water on my roof during the storm clean gutters are the key. Unfortunately I have had really bad luck with gutter guards and my gutters still getting clogged so I removed them.
The Following User Says Thank You to bryanp22 For This Useful Post:
djlandkpl (11-20-2013)
Deck Power Washed...now many days of rain before stain! mark2741 Painting 67 09-27-2013 06:32 PM
Exterior Door leaks at bottom corner of sidelight MTW Windows and Doors 13 09-26-2012 06:51 AM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 05:38 PM
Over-trimmed shingles are driving me crazy pipeguy Roofing/Siding 12 08-17-2008 04:38 PM
