Storm Door Mounting Area - One Side (jamb) Is Smaller Than The Other. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 10:35 AM   #1
Storm door mounting area - one side (jamb) is smaller than the other.
Home entrance has a entrance door and a sidelights on side of the door knob. The door jamb (close to door knob) is 1.5" smaller than the all other sides. For the storm door mounting area ie all side jambs should be even. Please let me know the steps and tools needed to increase the size of the smaller jamb to be even with others in order to install a storm door.
Please refer the attachment for the top view of entrance door.
Thanks,
Joe.
Storm door mounting area - one side (jamb) is smaller than the other.-door.jpg
joe_p is offline   Reply With Quote
Old 03-21-2011, 06:39 AM   #2
As a remodeler, I would try to think why this was done, and how does the top trim join the sides???. That is usually only trim and serves no other function. If that assumption is correct, which side you replace matters not, just make them uniform. It might be simpler to tear off both sides/top and replace the trim(brickmold) with vinyl brickmold. No more rot or painting(if it is white).
On older construction, that trim is often the anchor point for the jambs and the house framing connection. BIG nails(16D) thru the trim into house framing.
The Following User Says Thank You to Just Bill For This Useful Post:
joe_p (04-02-2011)
Old 03-24-2011, 01:43 PM   #3
Hello joe_p, this is a common issue with some door companies. Your door manufacture didn't ship the door unit "storm door ready". See picture below-- the depth around the perimeter must be the same depth as the area between the door and sidelite, regardless if there are one or two sidelites, most manufactures will automatically build it "storm door ready", and some need to be asked.
In the case below, this owner will need to add to the mullion (build out) between door & sidelites if he wants to add a storm door.
Tangelo is offline   Reply With Quote
The Following User Says Thank You to Tangelo For This Useful Post:
joe_p (04-02-2011)
Old 04-02-2011, 07:10 AM   #4
Thanks for the reply. Tangelo, I have the same issue as you have mentioned. I would appreciate if you could please let me know steps to add build out between door & sidelites .
Thanks,
Joe
The Following User Says Thank You to joe_p For This Useful Post:
Tangelo (04-07-2011)
Old 04-07-2011, 02:26 PM   #5
Thanks,
Joe
The difference between the perimeter trim (brickmould) and the vertical (stiles) between sidelites & door is the thickness. If you add the same brickmoulding to the areas between the sidelites and the door, then the storm door will fit flush with the surface. Just go to local big box store and purchase 2 pieces of brickmould each at 84", then you can trim the pieces on site to fit, nail it into place with 16d galv finishing nails, paint the brickmould, once the paint has dried, then you can install the storm door.
Before you install the door, make sure that the main door handle does not extend beyond the jamb, otherwise the storm door handle & the main door handle will hit each other, if this happens then you will need to build out the entire opening where the storm door is going, and build it out enough to clear the main door handle.
Let me know how it goes.
Cape cod side attic insulation problems (fun) capecodfun Building & Construction 1 01-27-2011 01:49 PM
Advice for new patio area Mike2181 Landscaping & Lawn Care 2 07-19-2010 08:48 PM
Thoughts on wiring new attached garage/hallway Mi Feller Electrical 45 06-18-2010 06:47 PM
how to vinyl side this odd area? DangerMouse Building & Construction 18 04-23-2009 03:30 PM
Anyone looking for a side job (Chicago Area)? Kyle HVAC 8 12-15-2007 02:38 PM
