Storm Door Issue- See Pics - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 02:16 AM   #1
Storm Door issue- see pics
I am planning to install a storm door but not sure how to do it. On the left side of my main door there are 3 sections of the trim which i have labelled in the pic (A,B,C), however on the right side I have only one section (C). Besides that the door handle also takes up lots of space. Any ideas?
I am also considering the possibility of installing a glass encloure in the front porch instead of the storm door right at where the main door is. You can see there is a overhang in a triangle shape. What do you call such an enclosure and where can i find it. Is it worth the extra cost?
shampoo is offline   Reply With Quote
Old 07-30-2012, 01:56 PM   #2
im no expert, but ive seen my brother install a storm door on his front door
modern storm doors usually come with a frame and are built to standard sizes, find out which size would closely match this opening (not larger than) then you may need to add some wood pieces to get the frame to fit
what ends up happening, the storm door will be smaller than the main door
RacerDave1 is offline   Reply With Quote
Old 07-30-2012, 02:01 PM   #3
I think this will help you install the storm door, I got this ehow article when I tried installing a storm door to my grandmother's house.
http://www.ehow.com/how_15282_install-storm-door.html
denyoung is offline   Reply With Quote
Old 07-30-2012, 02:19 PM   #4
Thanks guys,
DaveRacers, what i was wondering is if i need to add trim to the right side to create section 'B'.
thanks
Old 07-30-2012, 05:35 PM   #5
kwikfishron's Avatar
Rewards Points: 82
Yes, from what I can see in the picture you need to build out the trim between the right side of the door and the sidelight to make a storm door work there.
The trim on both sides and the top need to be on the same plane.
kwikfishron is offline   Reply With Quote
Old 07-30-2012, 08:18 PM   #6
thanks guys!
Old 07-30-2012, 09:44 PM   #7
Rewards Points: 6,652
The storm door frame will actually fit against section A. We discussed this same question some time ago on this board about a year ago.
Old 07-30-2012, 10:11 PM   #8
Great! Now i cant decide btw a storm door or an enclosure just for the triangle overhead.
Old 07-30-2012, 10:13 PM   #9
Figure out the height and all, and you can probably have a local glass shop make up the enclosure for you, then assemble on site.
Front Storm Door Won't Latch sciron General DIY Discussions 6 02-21-2011 10:47 AM
34" Wide Storm Doors Custom Size Only? kc27 Building & Construction 3 12-08-2010 01:34 PM
Replacing glass in older aluminum storm window gt2003 General DIY Discussions 3 11-26-2008 10:07 PM
To Storm Or Not To Storm... Matthewt1970 Building & Construction 1 09-22-2008 12:37 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
