Steel Entry Door Weatherstripping - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 10:35 PM   #1
Rewards Points: 14
I have an almost 40 year old steel front door. I have looked and can find no indication of who the manufacturer was. The original weatherstripping was a white, very large compression type that looked like the gasket around a refridgerator door. It fit into a slot in the door jam. It got pretty grungy so I pulled it out thinking I could go anywhere and get a replacement product. Wrong--The stuff you find in the home improvement stores is just too small and doesn't stick.
Does anyone on this forum know what the original product was and where I can buy it.
felinesmom is offline   Reply With Quote
Old 10-02-2011, 12:18 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,850
Try a glazing supplier or a hardware store. I have found some weatherstripping profiles at the big box stores and what you are describing is not out of the ordinary.
Tags
compression , steel door , weatherstripping
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
Replacing steel entry door gary d Building & Construction 3 11-18-2009 04:56 PM
Steel Entry Door Issues framinghammer Carpentry 6 06-25-2009 06:50 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 12:23 PM
