Stationary Panel In Sliders Removable? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-09-2013, 01:25 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,360
Stationary Panel in sliders removable?
Can someone tell me if the stationary panel in a slider permanent or can it be temporarily removed. I'm thinking for when moving new furniture or kitchen appliances in/out of the house, a huge opening would be a nice-to-have.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 06-09-2013, 01:32 PM   #2
Rewards Points: 13,694
Most can, look at the top and bottom for L shaped clips that can be removed.
Replace the whole door with a french door and never have to worry about it again.
Clutchcargo (06-09-2013)
Old 06-09-2013, 02:25 PM   #3
DIY staff
Rewards Points: 7,174
Yep---Most are removable,as Joe mentioned---I've only encountered one that I could not figure out---
Old 06-09-2013, 03:42 PM   #4
I have gas!
Thanks.
This would be an off the shelf HD Andersen 400. The sales rep didn't know.
I thought of the french door but I like the idea that of the screen glider so you can leave it open to get some air flow.
Old 06-09-2013, 05:04 PM   #5
DIY staff
Anderson---4 screws on the inside near the bottom
then L-clips top and bottom at the edge of the door,going into the track---slide it out a bit--then lift and pull the bottom .
Quick simple job.
Inside door is removed by unscrewing the long head stopper --inside top---with a bunch of screws--
Old 06-10-2013, 06:22 AM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Some entry level vinyl doors are the only products that I've run into where the fixed panel is not removable.
You can get screen units for French doors now. There are still some other challenges that come up though such as the clearance needed for operation. Ultimately hinged and sliding doors each have their own pros and cons.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
oh'mike (06-10-2013)
Old 06-10-2013, 07:32 AM   #7
Bill Kearney
Rewards Points: 1,174
Just be mindful not to mash, dent or otherwise damage the tracks when you're moving items across them.
wkearney99 is offline   Reply With Quote
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
