Square Inches In An Egress Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 11:10 PM   #1
square inches in an egress window
how do i figure out the square inches of an egress window?
russ.ford is offline   Reply With Quote
Old 07-16-2011, 11:26 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Just make sure the window you are looking at is certified egress window (there should be a stick for the inspector) and any good manufacturer will have necessary back-up.
It is more than just the square inchs since there are requirements for minimum height and width of the CLEAR opening. The other issue you have to face is an installation criteria. - It is the height from the bottom of the opening to the finished floor that can vary from locality to locality. Very costly to correct if it does not comply.
Dick
concretemasonry is online now   Reply With Quote
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
egress window kikipauw Building & Construction 3 11-10-2010 07:30 AM
egress window oilman Building & Construction 2 09-20-2010 06:20 PM
egress window wall saturn78 Building & Construction 2 05-10-2010 06:27 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
