Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 11-18-2011, 01:39 PM   #1
sprucing up a window with casing
I started out putting this in the wrong place, so I'll try again!
I have a 9’ x 4’ picture window in the center of our formal area, with just a simple marble sill and nothing else. I’ve been looking around for ideas on how to give it some kick with casing/molding, but can’t seem to find any stock material that I can use effectively other than the basic fluted wood available from the likes of HD. Anyone have any suggestions (or even better, pictures) on how to use stock items to create an interesting effect? Has to be stock, as I don’t have router facilities to give flat pieces a turned edge, for example. Note for the picture – the ugly old blinds are coming out!
timbo59 is offline   Reply With Quote
Old 11-20-2011, 08:07 AM   #2
Drywall return windows are sometimes a challenge to make look better. But without proper tools, it is hard to make things work.
Tear out the drywall on the sides and top, replace with 1x flat stock out to flush with the drywall. There is lots stock trim available, from plain ranch to very ornate, fluted, stamped designs, etc. Many are stain grade, or you can paint. Check home stores.
Defog window recap greenmax General Discussion 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
window casing bluefitness Remodeling 1 12-09-2008 07:34 PM
Correct way to install aluminum window casing? DavesHammer Remodeling 7 01-16-2008 01:39 PM
