Spray Foam Insulation - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 12:31 PM   #1
Rewards Points: 874
Spray Foam insulation
Any recommendations on which foam to spray between the gap of the R/O frame and window? i only know of Great Stuff and i know it can't be the expanding one.
Mstrlucky74 is offline   Reply With Quote
Old 03-27-2013, 06:49 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Just get the stuff that is made specifically for windows and doors. There are some formulas available at builder supply houses that I prefer over great stuff, but any closed cell, low expansion foam will suffice.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Mstrlucky74 (03-28-2013)
Old 03-28-2013, 07:52 AM   #3
Rewards Points: 13,260
The can will say right on it Window and Door.
It's low expanding.
Biggest mistake people make is trying to add to much. Leave it back about 1" from the face and let it expand so your not having to go back and cut it all out.
Old 03-28-2013, 08:11 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,786
Window and Door foam.
If you are going to the big box stores, its the light blue can in the Dow stuff.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 04-28-2013, 02:02 PM   #5
This is what you should use.
http://www.homedepot.com/p/GREAT-STU...7#.UX1j9cptCSo
k20vteck20 is offline   Reply With Quote
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
stone coated steel and spray foam insulation waternut Roofing/Siding 2 01-15-2011 07:36 PM
DIY 2 Part Spray foam Insulation kphares Building & Construction 1 01-10-2011 03:53 PM
spray foam insulation jdgeorge Building & Construction 2 03-24-2009 06:15 PM
