Spray Coating Window Sill With Rubber - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 09:55 PM   #1
spray coating window sill with rubber
Are there any downsides to spraying an exterior window sill with flexible rubber coating to protect against moisture/rotting. Would fill in cracks and splits nicely I would think.
superdow is offline   Reply With Quote
Old 08-13-2013, 07:54 AM   #2
Rewards Points: 13,750
Not a great plan. Going to look like poop, paint will not stick, not going to address the real issue.
Got a picture you can post to see how bad it is?
Old 08-13-2013, 01:05 PM   #3
Too Short? Cut it Again!
If it cracks and water seeps in you will be worse off. Usually the major damage comes from sills not being the right angle or deep enough. Most often it is the flashing around windows and under the sills (or lack thereof) that leads to the most damage.
Old 08-13-2013, 10:20 PM   #4
firehawkmph's Avatar
Rewards Points: 1,884
But Joe,
it works great for turning your pickup truck into a boat. I saw it on tv, must work.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
user1007 (08-16-2013)
Old 08-13-2013, 11:31 PM   #5
And it's so much fun to try and get shingles off once someone has sprayed a case of it all over a roof to save money.
Old 08-15-2013, 05:24 PM   #6
The wood will not "breathe"; Water will get in thru some crack that will eventually develop and can't easily evaporate [water as vapor is a LOT more volume than the liquid version], so humidity will accumulate under that rubber skin. When the moisture content of the wood reaches about 25% the fungal spores that are everywhere will hatch and the little critters will eat your wood with great enthusiasm.
Pro Painter is offline   Reply With Quote
The Following User Says Thank You to Pro Painter For This Useful Post:
Old 08-15-2013, 10:57 PM   #7
Registered User
Rewards Points: 5,520
IMO, use a water proof wood sealer first to protect the wood; http://homeguides.sfgate.com/keep-wo...ing-27167.html
Other tips; http://www.paintsource.net/pages/sol...d_surfaces.htm
Gary
Old 08-16-2013, 01:04 AM   #8
I suddenly realize a troll trend. I should have looked more carefully. The OP is a one time troll, and will not be back.
That said, it was not a question beyond comment.
I personally do not think you can fix sill problems by just coating them over. I think it all starts at the roofing, then you look at gutters, and then you look to make sure your sills are cut at enough of an angle to repel water.
And of course everything along the path of water needs to be properly flashed to move along faster. Roof, windows or whatever. And the gutters will not work if not clean.
You cannot fix problems or address window sill issues talking only about what coatings to put on them.
Rotted window sill pinkertonpv Windows and Doors 10 06-14-2012 07:34 PM
solution for old wooden window sill hohadcr Windows and Doors 11 06-02-2012 02:29 PM
Basement window finishing Dmoraski Windows and Doors 3 05-29-2012 03:08 PM
my fix for rotting outside sill on wooden window guest General DIY Discussions 6 11-06-2010 02:58 PM
